Tracking Boxes on a conveyor
illibilli
Apr 2016
horsens
This is probably a very often asked question, so my sincere apology in advance.
I am an mechanical engineer working in a small company, I mostly do machine design and FEA on daily basis. Every once in a while I get to play around with different systems, and I really enjoy learning and adding to my own knowledge.
But I´m completely stuck right now.
We have boxes coming in on a conveyor, depending on the content in each box it is pushed onto one of four lanes with a pneumatic pusher.
The content in the boxes are recognized with a vision system that I made and sends a signal to the existing AB Micro850 glorified relay.
There is a diffuse sensor before each of the four lanes that triggers the pushers.
I have spent all day trying to find information on similar solutions. The simple bool logic is something that I grasp very well. But when the methods used revolve around Bit Shifts and Stacks.
I am just not understanding on how to make this system work. Does any of you know about a good available source regarding this subject.
the software that I´m using is Connected Components Workbench
Cheers from the slow engineer
Hey guys, I have to work on a project using AB plc. I have 12 indeed conveyors from which boxes are enter into the main conveyor. The main...
1,953
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,150
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
248
Hi All. I have a very specific question about tracking using an encoder and bitshift register. We would like to use a Compact or Control Logix PLC...
40
1,738
Hello, I have a servo motor running a conveyor belt system. I do not have the exact circumference of the head pully and therefore I get some...
1,394
