tracking tags by scan in logix5000
robbm2k
Apr 2017
Wisconsin
is there somewhere in logix5000 to track/record tags for a short time to see what is going on with a tag that i might not be able to see on my own if it changes for a single scan? Found the trends feature, just want to confirm if that is the best option.
you can set a bit to be ON on every scan, with that bit you save your tag value, on next scan compare new value to old value if different then save new value and enter this new value to a fifo . If new value is the same as old value no change to the fifo.
The only problem is that your fifo must be big enough in order to save lots of values in case tag value changes continuously.
Trending is not a bad idea the problem is that the trigger is SLOWER than scan time, and may be you lost some values changed while waiting for next trigger.
Good Morning , I have been brainstorming , and researching about warehouse RFID and GPS systems. We have a large storage area with storage...
1,914
I am attempting to reject a bottle If the label fails. The rejection works fine at normal line speed but at low speed the rejector fires (air...
35
1,176
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
258
Hi All. I have a very specific question about tracking using an encoder and bitshift register. We would like to use a Compact or Control Logix PLC...
40
1,764
Hello, I have a servo motor running a conveyor belt system. I do not have the exact circumference of the head pully and therefore I get some...
1,413
