Transfer Error with Wincc Flexible
Berra
Mar 2007
Sweden
137
Hi anyone who can help me??
1.when a transfer the project from Wincc to the PLC i get the massage"Connection could not be established, check your settings,cable,etc".
2. if a use the pcadapter direct to the plc i get connection, but when a use the profibus cable between the plc and Op panel and have the pcadapter connected to the plc a get the massage in S7" the bus parameters could not automatically determined (online) there are no station on the bus sending the bus paramters massage frames. Set the MPI/PROFIBUS interface manually".
3. can a use the pcadapter direct to the op panel or must a change some settings??
Tja,
2.Since you can establish a connection between your PG and the PLC your cable and pc-adapter are working properly.
3.Yes you can, are you running WinCCFlexible integrated to Step7, make sure you have the correct transfer settings in STEP7, under "SET PG/PC INTERFACE".
Under this menu you have another good function called diagnostics, connect to your panel and click "Read". Now the adress of the panel should appear, marked w an arrow.
If this isn't working I think you have wrong communication settings in the panel, go in under settings in the panel and make sure you enabled the DP interface and settled the correct adress.
Lycka till
I have FTView Version 11 running on Windows 10 and I can't upload or download to any Panelview. I get the "Source selected is not a valid device"...
3,845
Block Transfer Error "The Requested Length is Different than Response Length" Good day, I just completed an upgrade from PLC5 to ControlLogix...
2,831
Hello Expert, i have illegal data transfer error while i compile below code and please point me where i did mistake :utoh:. That is only self...
1,582
hi,i have a PLC5 system with something wrong.the cpu was plc-5/80e.with 14 chassis 1771-A3B.the first 13 chassis each has 10 1771-IL 8 analog...
3,613
All, I am trying to upload a PV+600 file from running application in order to add some code, but I get the following error " The RSLinx Enterprise...
20
5,653
