Transmission Error Problems with E1022
c_mo'
Oct 2013
South Carolina
Hello,
I am brand new to this site and am hoping to get some help. I am trying to communicate with a Mitsubishi E1022 HMI using E-Designer software. I tried calling Mit. tech support but they weren't able to help me with my problem. They narrowed it down to the possibility of my USB/Serial converter, but I'm not sure.
  • My laptop is running Windows XP
  • I have E-Designer 7.5
  • I'm using a CAB30/3M Cable and a KeySpan, Tripp-Lite, Model USA-19HS, USB/Serial converter.
I was/am trying to upload a working program from on E1022 and then download it to another, but keep getting "transmission error". It looks like it's working, will even seem to be loading some of the blocks, but when it's done, there's nothing.
Any help would be appreciated.
I am looking for a method which transmit OPEN/CLOSE signal from "A" Pump Station to "B" Pump Station. (a) There is no wire connection between...
1,246
Hello, I have been playing around with the DDE/OPC topic configuration in RSLinx to make an excel spreadsheet that pulls live data from a...
1,752
I have a tool at the end of a 200m cable. Through this cable I am powering a 50kW/3,000V and a 1kW/480V motor, both with VFDs. So there is going...
42
12,996
I have a one thermocouple that is connected to temperature module 1769-IT6 that accept thermocouples on a compact logix 1769-L33E chassy.I have a...
1,411
Hello, experts! I poll some holding registers on Micrologix 1400 through Modbus TCP. The PC and the PLC are connected directly with Ethernet cable...
2,215
