Trasnfer data from OPC Server to PLC tag
jj79miro
Jul 2012
LA
Greetings. I am new to VBA and I have a task. Transfer OPC Server data displayed by the HMI using FactoryTalk Veiw SE to a PLC tag. I did the trick by creating a button to run the following command:
[OPC Server.Tag] = [PLC].Tag
The only problem is that this does not run continuously. I don’t know how to write a VBA code to do this continuously or if there is any other function on FTV SE to do this.
Any help is appreciated.
Thank You
Hey all, I have a project in tia wincc professional v 15 in a virtual machine. I want to transfer the run time on the same PC on host OS. When I...
1,135
Hello. I have a db which is 1000 INT, and this db is represented in WinCC as a raw data type set of 5x 400 Bytes. This set is read with a script...
31
50
161
Hi folks, I'm not as accustom with Siemens & WinCC, however I've been asked to increase the amount of data an existing application is logging...
70
