Trending in OP27
Randrukie
Apr 2017
Tullamore
Hello ALL,
I don't have much experience-thanks for help.
I am trying to configure trending on OP27 using ProTool. I just need to display graphically my PV and the curve it adjusts to SP.
I am using 6AV6594-1AA06-0AB0 manual but there is no mention about it , is it possible at all?
If not, is it possible to display trend on the laptop reading S7 300?
HAving the shape of the curve I can take my parameters for calculations- its college 'controls' project.
Thanks a lot for help
Regards,
Robert
You can definitely make trend curves on an OP27.
In the project tree, there is a "Trends". Here you have to add a trend. After that you can add a trendview to a screen and link it to the Trend.
This is from memory. I dont have Protool available, except for in a VM which takes too long time to fire up.
Hello All, I am having a problem with some of my trends. I am using Historian tags in my trends. I have 2 clients that look at the exact same...
860
Wondering if someone has a good solution for Datalogging and Trending. Don't have any specific HMI needs, so could run it on a PC or a VM. So if...
20
4,085
This isn't a question but more like a FYI. I was using a bunch of trends (around 15) each fully loaded at 8 pens each. Over the course of a few...
919
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,790
Hello all, Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a...
2,127
