Am I correct?
Everything I do is PC based so I don't worry so much about memory. If I am correct, why not up the number of samples and only display 300 at a time. If the machine was running all the time you would get more history but your still going to loose it when you power down.
My guess is that the data is saved in ram so on power down you would loose all your data. You would need to setup a log to log to a file then show a trend of the log if you wanted to keep it. Then you would need to worry about memory on the panel.what's the max that we can trend without a hard disk in this mp270 ?
