Trending Siemen's S7 data
Apr 2002
Burlington, Ontario
186
Hello all,
I'm new to working with Siemens. Iv'e got a S7-400 system.
Step7 Ver. 5.3.
I see that unlike Rockwell, Siemens Simatic Manager does not support local parameter trending. (e.g - trend an analog signal). I'm assuuming that since I'm dealing with Siemens, I have to buy a seperate program to do so?? Is there something some one might reccomend?? Siemens product or third party?? Found a couple on the net, e.g ServiceLab9, Matrikon (OPC server + Historian lite) etc. These seem like too much for what I want to do. Anything simpler out there??
Thanks,
Andrew Evenson
True, unless you are using the CFC language. I was hoping they would add it in version 5.5 because I really like that feature :mad:
What exactly do you need the trending for? If it is for tuning a PID controller you could use the "Control Parameter Assignment" tool from Siemens, it should be installed together with step 7. You can also configure a new operator panel in WinCC Flexible or ProTool and activate the runtime for this project on your laptop. If this is not enough you'll need a third party software or a real SCADA system.
Hello All, I am having a problem with some of my trends. I am using Historian tags in my trends. I have 2 clients that look at the exact same...
868
Wondering if someone has a good solution for Datalogging and Trending. Don't have any specific HMI needs, so could run it on a PC or a VM. So if...
20
4,114
This isn't a question but more like a FYI. I was using a bunch of trends (around 15) each fully loaded at 8 pens each. Over the course of a few...
935
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,834
Hello all, Is there a way to trend tags associated with AOI? Currently the selection is grayed out. The tag is a local tag and it resides in a...
2,154
