Trending with Intouch - historical
logicinn
Apr 2007
lohami-hagetaot
19
hi all
i have a problem geting the history trends to work
im trying to monitor temprature, im using s7-400 plc with wonderware software (archestra + intouch) when using realtime trends i get the data , with the history trends i cant get it to work
can any one shed some light please
thanks
sorry about the spelling
A few things to check:
In WindowMaker, under Configure, click on Historical Logging.
Make sure that the upper check box (enabled) is checked.
If you are using the 'application path' option to store the files, then the entire path cannot be more than 50 characters long.
If you are designating some other location then that location must exist, it will not create the directory for you
After that, make sure that the tags you want to trend each have the 'log data' box checked.
did it , no good. whhhhhhhhhy
first of all thenks robert
i did all of the above, but the trends still dont worko_O
how does the trend know wich log file to go to, where can i see it
and can i get access to the log file outside intouch , then may be i can use the info to build my graphs on an outside program
and again thanks for the help
Can you post a screen shot of your historical logging setup in windowmaker and maybe a screen shot of one your tags that you have enabled for logging.
On your Trend screen, double click on the trend. Does it have a name? If not, click on Suggest.
On your Trend screen, place a button on the screen. Double click on the button and under "Touch Pushbuttons" you will see the Action button. In the Action tab place the following line.
HTUpdateToCurrentTime( "HistTrend" );
"HistTrend" is the name of the trend. If the name of your trend is different, change "HistTrend" to the name of your trend.
This will update the trend to the current time and you should see the data.
John
will do soon
thanks for the help guys
sorry i was realy busy with some projects i didnt notice the replays you sent me but now i do and i thank you for them
i will post a screen shot of the configuration on monday when i get back to the office
and i will try the update button too
will let you know how it turn out
again thank you very much
I have the built in historical trending working almost like I want it but save for one thing. I call myself looking high and low, searching here...
2,290
Hello All, I am having a problem with some of my trends. I am using Historian tags in my trends. I have 2 clients that look at the exact same...
862
Wondering if someone has a good solution for Datalogging and Trending. Don't have any specific HMI needs, so could run it on a PC or a VM. So if...
20
4,091
This isn't a question but more like a FYI. I was using a bunch of trends (around 15) each fully loaded at 8 pens each. Over the course of a few...
923
This forum post I found seemed to reference the same issue, and if posts were still allowed on that thread, I might make an account there to post...
5,796
