InTouch 10.5 Historical Trending Size
bwhite
Jul 2006
Lakeland, FL
53
I have the built in historical trending working almost like I want it but save for one thing. I call myself looking high and low, searching here and reading the help files to no avail.
I know about the Historical Trend Configuration under Special and have the number of days set to save but I would like to be able to limit historical trend files to be limited to per cent of available disk space. Is there anyway to do this with the built in logger?
I know, I know, buy Historian but my client won't spring for it. What say you guys?
Ben
Not that I know of. Are you concerned that the disk space on the logging computer will be consumed by other programs generating files? You should be able to calculate the amount of space required for X number of logging days, but I don't know how to dynamically change the logging limits. Limiting the number of days and the number of files generated per day are the only relevant parameters that I'm aware of for controlling log files.
hi all i have a problem geting the history trends to work im trying to monitor temprature, im using s7-400 plc with wonderware software (archestra...
3,602
Hello to all of you! I am working with InTouch 2017 application for HMI. So far, so good - configuration is simple, there is two clients, each...
1,442
Hi !!! I'm getting rid of the old IT10.6 that was working on Workstation. I'm using servers with ThinClient (NAD enable). If I run the app, now...
1,393
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,865
Hi all, I have a project where we'd like to use InTouch for the HMI for a water plant. The water plant needs to provide monthly reports to the...
2,238
