Trio Motion and G code
irondesk40
Jan 2008
nc
630
we have had a vendor come in and suggest a Trio MC405 motion controller that can accept Gcode files and run the x,y and z axis similiar to a milling machine.
Has anyone had experience with these.
Did a search on the web and saw that Yamaha has used the same setup.
I attached a link to it.
We looking at it due to fact we are looking at duplicating a 3d printer to create a new product.
https://www.yrginc.com/integration/?name=GCode-Control-for-Yamaha-RD-V-or-TS-SD-3D-Printing
Trio motion
I used a Trio about ten years ago, but cannot recall the model. I can look it up when I return to the office tonight or this weekend.
We used a three-axis model to control a home-made saw for cutting granite.
I have used a MC405 on a single axis indexing application. It works fine, but it programs kind of funny. It always wants the laptop to be connected to a controller, so if doing offline programming, you must use their simulator. Getting online with it can be difficult some times.
Looking at it for possibly doing a 2d or 3d print type application we looking at since it is suppose to be able to use G code and perform the motion moves based on the Gcode generated from a image file.
Have tested theory with a 3d printer main control board but now need to move to a more industrial type set up for some new products the company i work for is looking to put on the market
I don't like the Trio software (MotionPerfect).
Trio started as a motion controller, then they are trying to make it a PLC but, in my opinion, with no big success.
I'm new to TRIO line of controllers, only used mitsubishi PLCs before. I have this MC206X controller which refused to accept connection via USB...
1,569
Hi all, A customer wants to replace the Allen Bradley PLCs with Trio PLCs in all the coming motion projects. And the drives will be Kollmorgen. I...
21
6,383
I know this really isn't a PLC's question but has anybody had any dealings with a Trio motion controller? I am trying to connect over a usb to...
2,298
Hi, We have machines throughout the world that use the Trio MC206 range of Motion Controllers. Currently, we have a customer in Wautoma, WI...
2,367
Is mc206 trio motion controller discontinued by trio-motion. We are really in trouble replacing an mc206 trio in a labeling machine . Any help...
2,914
