Trouble Connecting to PanelView 1000 via RS232
rupej
Sep 2014
NC
967
Was wondering if anyone had any suggestions:
I'm trying to connect to an old PanelView 1000 Touchscreen model# 2711-T10C16L1 via RS-232.
I'm using a 9300-USBS USB/serial converter with a 1747-CP3 cable to go to the port labeled "RS-232 DF1" on the PanelView.
I've gone to the setup menu in the PanelView to verify the comms parameters, which are the defaults.
In RSLinx, I've configured a RS-232 DF1 Device, (Verified correct com port) and selceted "SLC-CH0/Micro/PanelView" as the device type.
But in RSLinx, when browsing the DF1-DH-485 connection, the PanelView never appears, and thus I can't connect to it.
Is there something obvious I'm doing wrong? Thanks for any advice!
I've never really understood why the PanelView group used a DCE pinout (which requires a straight-through cable), but they did.
I am not sure if the little icon appears in RS-Linx but try this:
Worked for me few weeks ago
Confirm the RS-Linx and PV com Port settings are the same
Attempt an upload or download with the PanelBuilder 32
In transfer type select:
DF1 Point-to-Point RSLinx AB_DF1-1
I use a DB9 Straight though cable BUT I may attach a Null Modem converter.
I can’t remember.
I attached a screen shot
AB Recommended Cable
AB recommend cable for PanelView 1000 is 2711-NC13, I use it with a 9300-USBS Rev. 3.0. Never fails, just check what Com Port the 9300 is assigned to in your PC. Should be able to Auto-Configure in RSLinx. I had to verify working order for 1000 last week.
AB PanelViews are considered to be communication devices, DCE. Null Modem cables are used when both devices are either DCE or DTE, example: PC to PLC, both being DTE devices, needing crossover or Null Moden cable to communicate.
RSWho
One suggestion, in my opinion, I always told my maintenance guys to us RSWho to verify communication before trying to go online with any device unless they were sure of what they were doing. Can be a real time saver, and only takes a couple key strokes to check.
I have a new job programming PLCs and HMIs after being away from them for ~7 years. I am trying to establish a test setup with an old AB...
3,923
I have a problem connecting to a Controllogix L71 (version 20) via a 1756-EN2TR/C (Revision 10.0007). Secomea is a 3549 with the latest firmware...
1,679
Hello, I am very new to this new hobby and am having difficulties connecting to my PLC CPU. I am not sure if I am doing something completely...
18
5,200
I am having a hard time configuring my Micro820 PLC with Connected Components Workbench as a scanner for my fanuc robot. Any advice on this?
2,850
Good Afternoon, I'm currently trying to upload a program from an old GE 90-30 CPU with a Windows 10 laptop that is running Proficy Machine...
3,212
