Trouble Connecting to PLC
RyeGuy
Sep 2019
Toronto
Hello,
I am very new to this new hobby and am having difficulties connecting to my PLC CPU. I am not sure if I am doing something completely wrong but this is the setup;
Mac running windows 7 VM, I have thunder to VGA adapter which plugs into the PLC CPU and I cannot get it to link. I have my thunderbolt port bridged on the VM, and it is recognized in on the VM. But when I try connecting using the DirectSoft software it doesnt make connection.
Connecting UDP/IP I tried manually putting in the IP address of the driver and that doesnt make a difference
Any advice would be greatly appreciated.
Thanks!
I'm not familiar with DirectSoft, but I'm thinking a VGA adapter, even if it might happen to have the right number of pins, is not the right solution. VGA is for connecting to monitors.
For connecting via Ethernet you would need 1) an Ethernet cable 2) an IP on your computer that is in the same IP range as the device you are connecting to. Make it sure it isn't one of the IP addresses already in use.
Gotcha, I was hoping that would be an easy solution - Ive seen some that are RS-232 connectors but this specific one has the 15 pins.
Unfortunately this particular CPU (DL-250-1) uses a RJ11 6pin connector which I dont have, but I may have to go that route and purchase one
You didn't say which model PLC, but port 2 on the DL06 is a 15-pin high density Dsub which looks like a VGA port but is actually a serial port that can be configured as either RS232 or RS485.
It is the 250-1
So if I were to use the port 2 I would need to get an adapter for that VGA cable(or is it a whole new cable?) to serial before connecting it to my laptop?
You won't be able to use a standard VGA cable. You need to match the signal designations at both ends of the cable. I'm not familiar with the MAC's serial port but a typical PC RS232 serial port uses pins 2 and 3 for the data lines and pin 5 as the signal ground. Sometimes you also need connections to pins 4 and 5.
I don't have the pin designations for the DL250 handy, but the DL06 has +5V on pin 1. You probably should not connect anything from the MAC side to that pin
Thanks. Seeing as that something else I didn't think about and something new, how would one go about reconfiguring pins?
Because there is no standards for that.
Think it like when phone charge pin didnt have any standards.
There was lot of different pins and volts before USB charging and even now it can change.
The pin designations at both ends are fixed by the hardware. You will need to purchase or build a cable for the specific purpose.
At minimum for RS232 connection:
You need to wire the transmitted data pin on the MAC end of the cable to the received data pin on the PLC end.
You need to wire the received data pin on the MAC end of the cable to the transmitted data pin on the PLC end.
You need to wire the signal ground pin on the MAC end of the cable to the signal ground pin on the PLC end.
Edit:
My unfamiliarity with the MAC is showing. If the serial port on your MAC is USB, you will need a USB/RS232 converter.
I'd just order the correct cable from Automation Direct. They're cheap
Sounds like an easier option. However shipping to Canada makes that 20$ cable 60$ canadian by the time it gets here. Time to have some fun creating my own cable! haha
Appreciate the help !!
If you can solder and port is rs232 on both ends you only need schematic of connection.
But using wrong cable can take smoke off somewhere, even that rs232 have usually some protection
For port 2:
https://www.plccable.com/automation-direct-koyo-usb-d2-dscbl-1-port-2/
But you may be better off connecting to port one in which case I like the two piece solution using a generic USB to RS232 adapter and the Click programming cable. The generic adapter will have a multitude of other uses in this field. Port 1 (RJ12) will almost always be set up to work with programming software. Port 2 (HD15) can be set up for a variety of different protocols.
https://www.plccable.com/usb-to-rs232-plc-programming-cable-special-plctalk-net/
plus:
https://www.automationdirect.com/adc/shopping/catalog/cables/plc_programming_-a-_expansion/d2-dscbl
That 2nd link is to a cable that will work with several different A/D PLC models which use the RJ12 connector on their RS-232 ports.
I have a new job programming PLCs and HMIs after being away from them for ~7 years. I am trying to establish a test setup with an old AB...
3,923
I am having a hard time configuring my Micro820 PLC with Connected Components Workbench as a scanner for my fanuc robot. Any advice on this?
2,857
Hi, I am new and barely know what I am doing and I have some questions. I have a Direct Logic DL06 PLC with DirectSoft 5. I at one time had...
8,379
I have a problem connecting to a Controllogix L71 (version 20) via a 1756-EN2TR/C (Revision 10.0007). Secomea is a 3549 with the latest firmware...
1,681
Was wondering if anyone had any suggestions: I'm trying to connect to an old PanelView 1000 Touchscreen model# 2711-T10C16L1 via RS-232. I'm...
3,691
