TSX 17 PLC upload
Apr 2006
middlesbrough
:oops:Hi ,
i have been asked to replace a TSX17 24012 PLC so i have ordered the following from Schneider
TSXLPL72C5E software
TSX17ACCPC cable
will i be able to upload the program from the PLC so i can either convert it to modicon or alternatively to another plc(converting a printout).
regards
mark
yes you will but i think you will loose all the comments and tags of io and internal memory bits and words etc. If you can get the original that will be best.
alsoim not sure that you can run that software on windows. As i remember correctly you have to run it on OS2 from IBM. There are ways around that by downloading the virtual pc software from microsoft and install os2 on that virtual pc. But where you are gonna get OS2 installation disks is a whole different ball game
thanks,
i know with some plc's you need the original files but i was n ot sure with this system.
unfourtunatly ther is no chance of getting the original source code, i have been told it is dos and i have a old compaq laptop that should do.
mark
at least its dos. I was probarbly thinking about modsoft.
And dont take my word as final awnser as i am spitballing a bit. Havent worked with tsx17 for a very long time. will find out exactly if the comments and tag names will be lost
I have a TSX P57102 PLC and XBTF024510 screen. The screen is connected from the 25 pin port to the term port on the plc. I tried to connect to...
6,573
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
371
TSX-P57104 PLC (TSX Premium Telemecanique) What application software is compatible to read the logic existing? Is it Unity Pro or PL7 ? What...
1,829
Dear friends i Need pin out diagram of cable TSX PCX 1031 for Twido PLC.
5,236
Hi, I am a student doing a TR on replacing an old plc. I need help getting the program out of and old Telemecanique tsx 7 47 plc. What software...
3,509
