tsx 17 system bits
Snovach
Nov 2004
Does anyone have a list of system bits Sy:n 0-23, for Tsx 17
series PLC. This is a old Telemecanique PL7-2 software.
I'm looking specificly for the following; Sy1,Sy5, and Sy6.
Thanks !
SY01-> force cold restart, (no loss of data on return of power), when set to 1 by user it will be reset to 0 by system.
SY05-> internal timer, pulse stream 100ms on 100ms off
SY06-> internal timer, pulse stream 1s on 1s off
Hi there,
I am using TSX172 PLC. Right now the CPU is in stop mode. This happen after power shut down. I no have idea how to switch CPU to "RUN" mode.
Our production is stopped due to CPU in "STOP" mode.
Can anyone plz help to tell how the CPU can be switched to "RUN" mode???
Hi
Do you have the software to connect. It's very old and it's be a while but you can transfer the program to the Pc and there is a place to but the plc into run mode. I am also asking you to do this incase it has lost its program when it was powered down
Donnchadh
Thanks for the reply.
I hv checked it again, to put the PLC in RUN mode.
It looks that CPU program is lost. I hv downloded software PL7-2 from Schneider Electric web site. And now preparing a computer with Win95.
After that I'll try again.
i hv downloaded software pl7-2 and tried to install on computer with OS windows98.
but it says "error 251, user interface not installed correctly".
can someone help to get out of this?
I'm working on a Schneider TSX Micro TSX3722001 with an alternately flashing ERR and TER led. The machine has been idle for about 3 years and I...
999
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
62
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
152
Hello Dear Experts I have to read 2 words (%MW300 / %MW301) in a M221 plc (TM221ME16R/G) which have a embedded ethernet port. the reader plc...
747
My plc is stx micro 3722 My problem is err led is flashing I tried to re programme my plc with pl7 programme The pl7 tel me cant connect with...
373
