tsx07 pc to plc cable
cma189
Guest
C
I have recently aquired two tsx07 nano plc's with the pl707 programming software, version 1. The problem is i dont have the cable to connect my computer to the plc. I just wanted to make a cable but need the diagrams. Any other information on how to connect these two would be greatly apprectiated. Thanks.
--Curt
It is probably easiest to purchase a premade cable from Schneider or Niobrara Research & Development.
The TSX07 programming port is RS485, so you will need to get a convertor for your computer's serial port if you make your own. Also, I have not had luck finding an easy source for the mini-DIN 8 pin connector.
Hey Jim,
Thanks for the input, currently i am trying to track down the cable. From everything that i can find the number is TSXPCX1031. Is that the correct number? Another question is are these cables usually expensive, i got a hold of a shriedner supplier but they havent contacted me back yet. Thanks again.
--Curt
Ok i finally just bought the cable, it ran me 130 dollars. Now how do you get everything up and running. I try to connect the plc and computer and i just get a comm error.
I can't tell you how to wire the cable up, but I found the same 8-pin mini DIN port on the front of an Omron SP20.
After a little digging I found that a Mac serial port extension cable was a perfect fit. Make sure you get one with all 8 pins wired thru.
Sorry, after reading the rest of the thread I see the TSX needs the 485 conversion too.
hi everyone. i am currently working on converting an old tsx07 plc to micrologix 1200. is anybody familiar with the program instruction of...
3,901
A have a pneumatic machine who works with Telemecanique TSX07, a fixed the problem with the air, but the PLC operator starts to pulp a green light...
3,140
Can anyone help me with getting the program from a Telemecanique TSX07? I have the part# for the software and the cable. It only runs on Windows...
1,912
I have a machine with a Telemecanique TSX07 PLC that has an error light. I do not have the software or cable. Does anyone have a suggestion for...
3,626
Hello out there, I picked up a Square D TSX07 on Ebay not long ago to use on a small project. I think the programming software is called PL7 but...
7,880
