Tuning Servo
feisaladam
Mar 2024
Indonesia
Is it possible for me to tuning 2 servo at the same time, because this servo is connected by mechanical so I'm afraid that I need to tuning them on the same time, or is there any other recommendation for this application
The answer is yes but you must do it slowly and carefully. You must move the two actuators back and forth at the same time by issuing the same command to both actuators.
What we do is move both axes slowly from one spot to another and look at the trend. The trend should have the target position of both axes and the actual position of both axes. Since both axes are going from the same place from the same place you really only need one target position. After making a slow move you check for following errors. The actual positions should be the same or close. Then you increase the speed again I will then check to see if an axis is leading or following the target position and adjust its feed forward accordingly. Both actual position should be following the target position. Increas the speed a little more and keep adjusting the controller gains.
It is best to have a skew detect between the actuators and a following error check if the actuators are not following the target position. If there is a problem then both actuators need to be issued a stop command at the same time using the same command.
Okay, thank you. I will try to do it
I always thought that it's a good idea to tune a new servo motor but some people at work doesn't think so. We recently had to replace a bad servo...
1,864
This webinar was held yesterday. I didn't post a link to it. We had over 200 people attend it anyway. There was more question and answers on...
1,217
Hey all. I'm stuck trying to tune a 611U, can't find anything in Scout for the life of me. Is there some automatic parameter setup area I'm...
1,352
I am autotuning a servo motor (with Kinetix 300) using Motionview Onboard. #1) About autotuing's travel limit. I don't know what it is. When...
2,290
Does anyone have some sample code using the MRAT instruction to tune a Servo? I have a CompactLogix with a 1768-M04SE card. I've got my axis...
3,506
