Turck TBEN I/O Block Configuration
Nov 2013
Michigan
532
Have a job coming up where I'm using a bunch of Turck TBEN-L4-16DXP modules. They say they're configurable as inputs or outputs. I've downloaded the "sample code" from turck which is basically just a bunch of configured modules and no code. PLC is a CompactLogix 5069-L306ER.
I see an input assembly and an output assembly, and I've looked in the manual and correlated the I/O points with the assembly arrays. I have a few of these modules where I want to do half input and half output. So I'm wondering if there's any configuration I have to do to the Block I/O module itself. I can't find any information from Turck as regards that specific question. Do I just use the Output Assembly addresses for outputs and use the Input Assembly addresses for inputs and that's it? Or is there some special configuration software from Turck I need to set which channel is an input and which is an output?
hello, it´s almost a year but i remember i´ve used build in web enviroment to setup this.
I’ve used these a few times. You’re off to a better start then I was. I couldn’t find any documentation that correlated to the input and output arrays. I basically just powered it up and started flagging the ins and toggling the outs and figured out the map.
I don’t believe you need to do anything to configure a point as an in or an out, at least I didn’t. I will say that they are sensitive to wiring on the commons. I left a few off of some of the points when testing and it seemed to affect other banks of points. I was getting inconsistent results until I finally wired up everything as if I was using all points on the module.
Hey all, I'm trying to set 4 of the last I/O to be outputs. The manual says to push the set button (which I assume is the one next to the rotary...
3,288
Hey all, does anyone of you have some experience with combination of BL67 gateways and TBEN L1 IO modules (using Modbus tcp)? It looks to me like...
884
Hi all, Hoping someone out there has used these units and can give some honest feedback, are they great or rubbish? From what i can tell, they...
1,266
I have been Tasked with wiring an i/o link block to an existing machine, and use a few proximity switches and a q4x laser distance sensor to...
421
Hello Experts, I have a Turck Encoder connected to P+F IO Link master communicating over Ethernet/IP with Allen Bradley PLC in Studio 5000 v34...
727
