Turning off PanelView animations
Burch
Jun 2014
Michigan
54
I am using some graphics from the standard FT View Library.
I don wan to use the built in animations. For example, I am using some valves and a fan graphic. The fan moves (yellow blades) and the valves flash red and green.
How can I turn these off?
Thanks,
Burch
Open your project file, go to the screen where the symbols are used. Right click on the symbol and there will be a menu that appears. Click on animations and scroll through the tabs until you find the expression or tag that is controlling that particular animation that you want to eliminate. Delete the tag/expression and you will then have a static symbol on the screen if that is what you want. You can also change colors, rotation, visibility, etc. from there. Close and save the screen when you are done, create a new runtime file and download to PV. Hopefully this will help you and I understood what you were asking.
I have a strange problem. We have 6 cart, all setup, wired exactly the same. On two of those the QBAD_I_xx does not turn off. The safety card is...
1,550
Having an random problem with this PLC. The inputs and output turning off then suddenly turning back on. Still have 24 VDC on the inputs and 120...
2,154
The following is the way I call a bunch of routines from the top level routine. It works fine, however I discovered that I can not restart the...
2,633
Our Automation Direct HMI's one push button is activating on and off on its own without anyone touching the HMI button. I power cycled the HMI...
4,121
Hey guys, We have experienced a few weird issues with some PLC 5 racks recently. On some cards, the outputs will turn on and off real rapidly...
2,545
