Twido CPU Model: TWDLMDA40DTK
donhamon
Jul 2014
muntinlupa
21
Ok first, I have Three (3) TWDLMDA40DTK PLC CPU. I'm planning to have a master and two (2) slaves. Can someone save me from here... I'm having a hard time establishing communication between these three CPU's.
Second, does anybody know how to fabricate its communication cable the 8 pin mini din cable?
Thanks in advance!!! Hope someone help me... 🤞🏻🤞🏻🤞🏻
What connection are you using, RS485, Ethernet etc ?
take a look for twido help file for com_macro build in functions.
http://www.plctalk.net/qanda/showthread.php?t=58641
http://www.plctalk.net/qanda/showthread.php?t=53434
You can use rs232/485 or ethenet (ethernet modbus master only if twido have build in ethernet port)
its better have 2nd com port on plc, so you can also debug program same time. You can use programming port also for rs485 modbus, but then you can't communicate same time than program.
for cable:
http://www.plctalk.net/qanda/showthread.php?t=67618
http://www.plctalk.net/qanda/showthread.php?p=403630
p.s TWDLMDA40DTK have only programming port, so it's recomended to buy additional communication port for PLC's. (NOZ485T)
Hi guys!! I'm New here and new with this type of plcs i have TWDLMDA40DTK and i need to get a copy of the program and i don't have an original...
696
Dear friend, how to read the input register (3xxxxx) of device from twido plc. i have tried the comm macro but it always read the holding register...
1,573
Good, how do I control through an Analog output of a valve, that is, open the valve from 10% to 10% until it reaches 100%, and then close it...
2,248
Hi! I bought a secondhand Twido base unit to help me learn programming and also faultfind expansion modules (one of my customers machines uses...
1,700
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,416
