Twido Schneider Electric connection fault.
allovaro
Oct 2015
Rostov-on-Don
Hello, I have a Schneider PLC Twido TWDLCDA24DRF, and I need to change some parametres. I have RS-485 converter and made connection cable by myself. But I can't to esteblish connection with PLC. In modbus driver in Runtime table i see how Frames sent and Checksum Errors increase and Twido Suit 2.31.04 have error:
"Communication error. Check the Modbus Driver parametres, controller connections or power supply."
Pin-out of cable at miniDIN8: 1 - A, 2 - B and 7 - GND.
My communication parametres: speed 19200, 1 stop bit, Parity - None, 8 bit, 5000ms TimeOut.
What I'm doing wrong?
Buy a Schneider cable - they work. Also are your serial interface settings the same as the PLC? They may have been changed in the PLC.
So are what software are you trying to connect with? You should use twidosuite which is a free sfotware you can download off the web.
For only one PLC for one change in program it's to expensive to buy this original cable, and delivery is to long. As I guess it's true settings, because only with this parametres I see in modbus driver runtime table checksum errors. With different ones only timeout errors.
Yes I use Twido Suit 2.31.04 in monitoring mode at first. Do I need to connect 5 pin in miniDIN8 or not? Do you know? Thank you.
Try to connect pin number 5 to GND.
Please check the attached picture.
Yeah, thank you I saw this picture and tryed it. It doesn't work. It seems I understand why nothing works. Because my RS485 convertor is 4-wired and can't work in 2-wired way. Going to looking for right convertor...
Hi, i am using Twido PLC controller TWDLMDA20DRT with extension modules or sometimes modicon M340 for research and projects. I know that for...
2,608
Hi! I bought a secondhand Twido base unit to help me learn programming and also faultfind expansion modules (one of my customers machines uses...
1,701
We're a second hand machinery merchant. We've just had a machine arrive that has a Schneider Twido TWDLCAA24DRF PLC and a Magelis XBT-R411 HMI...
2,421
Hello Every one, This question came around in my place of work (MOAWP). It appears very simple on the surface, but I could not get right when I...
1,908
3,533
