Schneider Electric Twido/M340 OPC Server
dwpang
Aug 2012
singapore
68
Hi, i am using Twido PLC controller TWDLMDA20DRT with extension modules or sometimes modicon M340 for research and projects.
I know that for controlling and monitoring purposes i can use a HMI such as HMIGTO4310 for these purposes but it would require building panels to house the HMI. Which i do not want.
If i can use a pc or server it would be much better. Any OPC servers available for the twido or M340 as mentioned?
Simple PC server and monitor for presentation.
For twido i know i have to use a RS485 cable and for M340 i can use ethernet cable. Any recommendations or suggestions, e.g. pros and cons?
Thanks.
Twido and M340 have Modbus, CANOpen and Modbus TCP/IP options, and both can be RS485, RS232 and Ethernet. So you can use any OPC or SCADA with support for Modbus, Modbus TCP/IP and CANOpen. Google litle bit and you will find free SCADAs and OPCs for small projects (cca up to 50 tags).
Very important thing is that if you can choose, choose M340, it is two light years better PLC than Twido, just not comparable.
Hello, I have a Schneider PLC Twido TWDLCDA24DRF, and I need to change some parametres. I have RS-485 converter and made connection cable by...
3,363
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
252
Hi, I am stuck with these SE cartridges, I am trying to add a second serial port rs485 to a M221 PLC. What is the difference between TMC2CONV01...
124
Hello, Does anyone know why this AMO 0410 or AMO0410 module flashing all 4 channels with green LED and the IO LED on the display is solid red ...
493
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I...
480
