Twido Soft V3.5
kire
Apr 2014
UK
55
I`m new to Twido Soft V3.5 (old project).
I need to make a communication check with the HMI panel.
My plan was to make a function in Twido count from 0-999 and then start on 0 again and count to 999.
The HMI panel will then check these value for update...
Is these possible in Twido Soft V3.5 and how?
Thank you for using time on me.
Yes its possible. Rather use twidosuite. The twido soft programs are compatible with twidosuite. You have built in counters that you could use or use an operation block to increment a %mw
Al this said the screens driver should monitor the comms and normally will display some kind of error if the comms are not working.
I figured it out, thank you.
Hello Has anyone ever talked to a Schneider Twido PLC with a direct Logic DL250 PLC. I am tasked with this i am going to have to network my fleet...
1,338
Hi guys!! I'm New here and new with this type of plcs i have TWDLMDA40DTK and i need to get a copy of the program and i don't have an original...
692
Dear friend, how to read the input register (3xxxxx) of device from twido plc. i have tried the comm macro but it always read the holding register...
1,571
Good, how do I control through an Analog output of a valve, that is, open the valve from 10% to 10% until it reaches 100%, and then close it...
2,244
Hi! I bought a secondhand Twido base unit to help me learn programming and also faultfind expansion modules (one of my customers machines uses...
1,697
