TwinCAT, EtherCAT and Altivar Communication
ljoh
Oct 2016
Copenhagen
Hello,
Does anyone have some good advice on using TwinCAT to control Altivar Drives from Schneider Electric. In this example I am using ALT320 drive and TwinCAT 3.
I can communicate and control the drive with the standard adresses:
Out:
Control word
Target velocity
In:
Status word
Control effort
My problem is that I want to get more feedback from the drive. And I only get these four parameters in TwinCAT PDO mapping.
I have tried adding for example com. scanner address 3202 output freq to the drive in SoMove software. But this doesn't change anything in TwinCAT. Even if I make a new project scan for the box again.
My biggest doubt with this is that the ALT EtherCAT manual says that I need to use the com.scanner called OCA1...6 and OMA1...6 and not the standard NMA1...8 and NCA1...8.
But I cannot change any values inside the OCA/OMA com scanner. Has anyone any good advice to this issue. I'm trying to figure out if my problem is in the Schneider or Beckhoff setup.
I would be very greatfull for any advice.
:confused: :confused:
Hello. I must be doing something really dumb but I cannot crack it. I have this one EtherCAT device and my CODESYS program works as expected. The...
1,472
Hello all, First time I have to use twincat. My configuration is very simple: A CX1100, One EK1122 Ethercat junction and two Unidrive SP inverters...
2,117
Hi, May someone could help me concerning the use of TwinCAT as an EtherCAT master? I must set this up only to verify if a slave is working...
2,081
Hi all, I'm working on BeckHoff's EtherCAT Device EK1101 (Coupler). My project is to write an application which can communicate to this...
16,750
I am using twincat 3 to send some strings over TCP/IP. Where the server is a sensor and my PLC is the client. I noticed that the sensor didnt...
88
