TwinCAT problem download
vaibaras
Supporting Member
May 2014
Kaunas
Hey,
when I declarate new local variable in function block FB1 in TwinCAT PLC control and try download this block to PLC receive message see in the picture. I find in MAIN(PRG) declaration FB1 : FB1. Maybe thiis it is reason?
I hope someone can help me.
And thanks for your time in advance.
yes please use other name inside your main program, so declaration should be FB01 :FB1;
and in the program change it too.
Hello everybody, I have a problem with TwinCAT 3. When I try to activate a configuration and start IPC in Run mode I receive an error AdsWarning...
5,685
Hello guys, I have a problem with the new release of TwinCAT HMI ( Not TwinCAT PLC HMI or visualization) , the problem is as follows : 1) drag...
2,459
Hello guys , i have the following problem : i have a motor that runs a semi-vehicle on rails (AM series from beckhoff ) & a distance sensor...
9,281
The solution explorer in Microsoft VS only show I/O. How can I fix this so it can show the other item such as SYSTEM and PLC.
1,589
Dear Members: I am new to Twincat System. I am working on a project. I have connected CX9020 with my laptop through ethernet cable. I was able to...
4,615
