Two motors dependent on one another ladder logic.
I do not understand how to apply conditions for one motor to another. I don't need the complete answer but I need to know where to start. I am new to ladder logic and having a difficulty in applying latching with the given conditions for two motors.
1. Show your logic for starting and stopping the oil pump motor, including keeping the motor running when you take your finger off the start button.
2. Show your logic for starting and stopping the main motor, including keeping the motor running when you take your finger off the start button, but leave out the part about requiring the oil pump motor to be running.
3. Figure out how to modify the logic in #2 to require that the oil pump motor be running before you can start the main motor. Make sure that the change will also shut down the main motor if the oil pump motor stops after both motors have started.
Thank You so much. I figured it out.
Dear colleagues, hope you can help on that matter. We have a project where we need to control 3 servomotors to move a auger feeder system...
38
1,172
Hi currently my existing PLC using AB motor & driver to spin production, however customer want to another set, if this possible we use different...
221
In a control System, I need to move 3 motors attached to roller in stages with speed of 1 to 2 RPM and the torque of motor should be 8-10 Nm...
829
I'm working on a design phase for a costumer and they've requested PM motors for all conveyor belts throughout the system. We have a gapping...
524
Hi guys, I have a problem with setting up the parameters for PowerFlex 525. So we have 4x motor connected in parallel to 1 PowerFlex, each motor...
1,085
