UAC Settings In Windows7 RSLogix 5000 FatalError
gbradley
Apr 2002
Corona, Ca.
1,637
I thought I would share this in case anyone else has a similar problem.
All of a sudden I was getting Fatal Errors when trying to Start up RSLogix 5000.
RSLogix Fatal Error
Error information has been generated
RSLogix Fatal Error
Version V20.1.00 (Release)
Source File: unknown
Line number -1
Function Method Unknown
OS Version: Windows7 64-bit (service Pack1-build 7601)
Thread Id:00001f30 (7984)
Error 0xc015000f (-1072365553)
0xc015000f – No message available for Error
Line number -1
At first I thought, there must be something wrong with my Activation, no that was OK.
Then I thought that there was something wrong with the Install.
After Uninstalling and installing, I was still getting the same error.
The problem was referenced in a Technote 186508 (You need TechConnect to see this)
I also opened a ticket, and got this response:
Hello George,
Main cause of this error you had is because of this User Account Control Settings. Our software need it to be set to “Never notify”. Sometimes when you update your Windows, it does change this settings without ever notifying you. So please keep in mind to check this settings after every Windows update.
Apparently on a Windows Update the UAC settings may have reverted to Notify which was somehow messing with the RSLogix5000
Anyhow, I changed both the shortcut to Run as Administrator, and the UAC Settings and I got it to work.
I frequently turn off UAC for most of my Scada systems.
Wonderware even shows you how to turn of UAC as part of the install.
Gbradley,
Many thanks for the fix to RS Logix 5000 Fatal Error.
Just Starting out and getting this error also.
Once again thanks.
Bann
Is it still required to have UAC off in windows 7 with most Rockwell software? Does it really make a difference anymore?
2,235
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
132
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
961
Hello. I cannot change the SendClock settings for a PROFINET IO device. I need to slow down the CODESYS PROFINET IO controller. What am I doing...
199
Hey all, I wanted to discuss an issue with achieving a constant flow rate of around 10 GPM on a glycol circulation pumps in a 1200-1300 PSI...
950
