Ultra 5000 servo feed help
loundeb2
Jul 2010
ny
111
I have a PA Industries servo feeder with an Allen Bradley MPL motor and Ultra5000 drive. I'm only using a single limit switch which rides on a cam attached to a press. I'm using the NO contact as the feed cam signal and the NC contact for the reset cam signal.
the problem is I keep getting a "sync fault" error in auto. I can jog for/rev without a problem. The limit NO contact closes, but I get no motion, then when the NC contact closes, I get the fault. No drive errors. I've isolated the limit circuit and wired a limit directly to the drive with the same results. Awhile ago, the connection block on the motor got pulled out by the cables, I rang them all out, secured everything, reinstalled and it worked fine for about a month, now this. Could they be related?
My company has a customer that has dozens of these servo drives on their presses. I'm at home right now, so I don't have access to the best information, but I remember two 'gotchas' on these drives. One is that the feed and reset 'windows' need to be longer than just a quick blip - maybe 30-40 degrees of press rotation, minimum. The other is the feed needs to be complete, BEFORE the feed window ends. If the signal changes from feed to reset, before the servo is done moving, you will get a fault.
Thank you for the help. I have figured it out though. Apparently, the feed speed and accel/decel rates are located in the "tools" menu, even though the manual shows it in the "oper" menu. One of the machine operators must have changed the tool number to one that hadn't been set up, so I had zero feed speed, etc.
Problem with RSLogix 5000 homing of Sercos Ultra 3000 and soft overtravel limits Hello, I have Version 20 RSLogix 5000 successfully working with...
3,028
Recently i have faced ultra 5000 drive failure. when i switch the power i got sparks coming from incoming side of the drive(without connecting...
1,265
Hi ALl I got online to tye Ultra 5000 and uploaded the file. I would like to look at the programs, which is in a format of .exe. Do i need the...
3,763
Hi all Can someone please tell me the cable Pin out to connect to an ultra 5000 And which port on the drive I connect to please. I have...
2,040
I have been trying to modify some existing code on an ultra 5000 drive. This drive also communicates to micro1500 LRP. All I'm trying to do is add...
1,927
