Ultra3000i Current Limiting
OkiePC
Mar 2005
ENE of Nowhere Oklahoma
11,794
Greetings!
We have a small conveyor made up of metal bins that catch product with an indexing motion. It is controlled by an Ultra3000i indexing servo drive. Today, a technician told me that he has never seen the drvie fault, even when the conveyor gets in a serious bind, it just rips itself apart.
He asked me to try to limit the drive current so that it would fault rather than create so much damage. I found a cable and fired up the laptop with Ultraware, connected to the drive and found the only place I could adjust any current setting was under the "Faults" branch "user current limit". The value in the drive was 255 amps! The drive/motor tab showed a peak current limit of 32amps.
I monitored the drive in normal operation and found the peak current to be 9 amps. I set the user current limit to 15 amps for now. I am not sure if what I did will help. Apparently, the bins on this conveyor come loose and hang up on the frame at least once a week so I should find out soon enough.
Can anyone tell me if I adjusted the correct parameter?
Thanks,
Paul
Wrong spot. Double-click on the drive in workspace and change the current limits.
By changing the "User Current Fault", I suspect you will make more work for yourself. Everytime it happens, you'll have to come out and hook up to the drive to clear the fault.
By the way, I couldn't find the Current Limits the first time I looked for them. I had to call A/B.
It's been awhile since I messed with an Ultra3000, but you should be able to do it online. Just becareful to save your settings properly. (By dragging the on-line drive to the off-line drive.) This is very non-intuitive.
agarb said:
...Just becareful to save your settings properly. (By dragging the on-line drive to the off-line drive.) This is very non-intuitive.
Yeah, I spent nearly an hour figuring that out the one other time I have been online with one of these drives...thanks again...Paul
Hello all, I am brand new here :cool:. I'm limited in my controls knowledge but always trying to learn more. I recently started working at a...
335
Hello, we have Ultra3000i drive(2098-DSD-HV050X-DN) with motor allen-bradley (MPL-B4540F-M) and smart encoder, indexing mode. We had defect at...
909
Hello, We have a project we are working on here at the plant. 2 AB Ultra3000i with devicenet, SLC500 5/03 with devicenet scanner. I read the...
16
3,737
I have an Ultra3000i Allen Bradley drive that went bad, I have a backup of the parameters and after replacing the drive I was wondering how to...
1,389
Hi, I am trying to connect to an AB 3000i servo drive through an SLC 5/04 using a 1784-U2DHP USB to DH+ converter. The servo drive is connected to...
3,854
