Unable to Delete Tag in RSViewSE
modicon2
Guest
M
When I attempt to delete an Alarm Tag in RSViewSE, I get a popup window stating "Unable to delete tag; Unable to remove tag from realtime database manager; Cause: There are other applications using this tag:
How do I tell what other applications are using this tag?
I just want to delete it.
Any help would be greatly appreciated!
I know this is old but I'll answer it anyway. The application that is using the tag is the alarm server. If you stop the alarm server (alarmoff in the command window) then you can delete the tag. You will then have to turn the alarm server back on with an "alarmon" + switches in the command window.If turning off the alarm server is not possible you can remove the alarm from the tag and then wait for the next time either the computer restarts or the project is shutdown and restarted.
I've got an HMI distributed application for this customer, but we recently changed it (in our office) to a network station because distributed...
8,349
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
255
I've posted this on the ptc forum as well, but no luck with an answer (waiting for my service contract number) I keep getting the following error...
128
I have just installed Studio 5000 V30.11 on my Windows 11 Pro machine. First I had an "Invalid Pointer" error that required me to update Factory...
124
Hi, One of my customers has an old fabric tensile testing machine. The IC # AD7501KN of its controller has malfunctioned. This IC is related to...
86
