Unable to Open Omron CX Programmer Project
isteak007
May 2009
NewYork
216
Hello,
I am unable to open a CX-Programmer project file (CXP).
I am using V9.3? Can any body tell me why this two project file is not opening.
Do i need more upgrade version?
Attached Omron project file.
Hello,
I am still unable to open the project, Using v 9.4
My software stop working when i try to open the project.
Can you give me any screenshot of your software? Which OS you are using?
I think the problem is on language maybe there is some Chinese character which my software unable to load.
I was able to open both files using CX-Programmer version 3.2 and CX-Server version 1.7. However, there are many rung comments that appear garbled, same as in Sergei's PDF 9.4 version (probably because they were originallly in a foreign language).
I will save them as a version 3.2 file, then you might be able to open them (but it seems unlikely). Can you open any other known-good file?
Uploaded this project from a PLC that we need to make changes to. I am trying to figure out the reason I am unable to open the actual logic. Do I...
2,263
Hi, Way I cannot open the project? GX works 2. Yesterday I closeted the project today I cannot open.
4,231
Problem Faced: • We are unable to connect with CPU via Rslogix 5000 • Whenever we try connecting we receive an error “Error 701-8004250A.Failed to...
19,720
Hi All, When I try and run WindowMaker I get the follwoing errors: 1. Corrupted Database 2. Read Error 3. DB cannot be loaded. Are database files...
17,377
Hi all, I'm not that familiar with Mitsubishi software but I'm having difficulty opening a .GXW file. I have both GX IEC Developer 7.04 & GX...
5,960
