unable to open panelbuilder32 file
I am having the same problem here at my facility.
I have 1000's running firmware versions 4.41 and I have multiple workstations from which I can upload/open the projects from. I have versions 3.8 and 3.81 running on workstations with 2000 and XP. I have a few panelviews that I can upload and open and a few that I cannot, and it makes no sense. I have crused the AB Knowledgebase and could also find nothing. I am hoping to get an AB rep in here next week, if I figure it out I will put it up here.
I don't have any problems when I attempt to upload/open from firmware version 4.20 panelview.
Unable to open Panel Builder 32 Files FIXED
Hello Guys, let me share my experience
I was checking some PB32 Files PVA, the interesting part is i could open some that were on a network but could not open ones that i copied to my laptop, i check their size and everything and at the end i remmbered something similar happened to me with a slc file, the path where i had the PVA file was too long i guess, so i copied the files directy to C: and i was able to open all my PVA files
try this =)
LoL
LOL!!!!
Well i didnt noticed the date, actually i had the problem today... i looked for an answer in google, got here, didnt find it neither, so i guess someone could have this problem again, hopefully they can have an answer =)
Fixed my Panelbuilder32 not opening its own upload...
LOL!!!!
You fixed my problem with a PV600. I uploaded as a .PVA to the root C:, opened it in PB32 v3.8.3 and then saved it as a .PBA in my normal directory.
THANK YOU, Bolatov!
can anyone please help me with open this file(.*pva). it shows me file corrupted or low disk space or not a panel builder file. my panel builder version is 03.83.01(build 7)
i cant attach my file ..if any one could help me please send me mail [email protected]
thanks
sorry i didn't notice the attach file icon on the top, anyway thanks for your reply
please help me to open this file. the version of my panel builder is 3.83.01
i think this is the latest version
thanks agin
PB32 v3.83.01
please help me to open this file !!!! I tried with all the possibilities,which i could.
if it is open plz convert to .*pba file.
thanks
This appears to be a Panelview 1250, I'm not sure, I may be wrong but Panelbuilder32 can't action this. It needs a different program.
There should be someone on this forum who could verify this.
Steve
It would appear that its a pv1250 plus, you would in that case require factorytalk to action it
Thanks for looking into it nehpets.
but it is panel view 1000 (2711-T10C3) SER C
REV B ; FRN 4.10.
I downloaded the file using compact flash card.
when i was trying to download the panel view application using DH-485 network, I got error at 99% "error-4008 terminal report bad data count"
so i have no options to upload that application from panel view.
Does it open , if i downgrade my panel builder ?? 3.83 to 3.82 ?
any other option ?
thanks again
Probably like others I opened the 'PVA' file using Notepad and saw multiple references leading to the assumption that it is for a Panelview 1250. Is it possible there was already information or files on the Compact Flash card which is mixed into this file?
Hi In the first...thanks to the friend #Mickey for his help to me with communication between panelview900 and rslinx... second: when I start to...
3,836
Uploaded this project from a PLC that we need to make changes to. I am trying to figure out the reason I am unable to open the actual logic. Do I...
2,249
Hi, Way I cannot open the project? GX works 2. Yesterday I closeted the project today I cannot open.
4,201
Problem Faced: • We are unable to connect with CPU via Rslogix 5000 • Whenever we try connecting we receive an error “Error 701-8004250A.Failed to...
19,659
Hi All, When I try and run WindowMaker I get the follwoing errors: 1. Corrupted Database 2. Read Error 3. DB cannot be loaded. Are database files...
17,342
