unidrive closed loop vector control
irondesk40
Jan 2008
nc
630
Is it possible to operate a unidrive sp in closed loop vector contol to drive a roller that is turning in a cradle type configuration and the encoder be mounted on a seperate roller then fed into the unidrive to maintain the required drive speed for example you set it at 5 ypm and the roller the encoder is mounted on tells the drive it is only actually turning at 4.7 ypm due to slippage. Hope this makes this sense.
Hi Irondesk, yes the SP can easily perform this. You will want to get a SM-Unversal Encoder Plus card to bring in the second encoder. In fact, the base drive can handle this without needing a programming module (SM-Application or SM-EZMotion).
Hi, has anyone had any experience setting these drives up in closed loop Vector mode? The issue I have is with a Unidrive SP, and encoder card...
5,142
hello everyone, trying to find a way to read/write memory of the PLC that is inside Unidrive M700 over Ethernet (modbus TCP) using device/server...
564
Greetings experts, We have a 'Control Techniques' Unidrive 3405 in an older machine. It appears that the drive parameters are recorded in a .CTD...
733
Hi We intend to replace our LENZE EVS9326 EP with a Control Technique Unidrive SP. The machine is a simple one; PLC send ABZ pulses to the drive...
2,057
Looking for a Modbus address manual for M700. Modbus address is same as the Parameter number for 16Int parameters. But it is different for 32Int...
2,003
