Unique HMI password...
MS Dos crashed after 128 files on root folder. Who remembers anymore. 🍻
Windows stops working on that drive (can't say crashes) if there is anything over 256 objects on the root - files &/or folders.
And, the files and folders on the drives are still limited to 8 characters with 3 extensions, Windows runs an interpreter in the background that knows Progra~1 is Program Files, for all files and folders. Open Command Prompt and run DIR for a directory of the real names on the drive.
Nope, I disagree that.
Windows uses max 255 (or 257, 260?) characters for filename, but it can be backward compatible with old style.
https://en.wikipedia.org/wiki/Filename
Hi, I'm looking for a method to uniquely identify TP1200 HMI panels. At first we tried to use this: Dim object Dim computerName Set object =...
2,177
commentaire communiqué siemens s7-1200 avec vfd delta ? (cablage et sur tia portal )
152
Hi there I've got a module in a project that has started 'faulting' (i.e. the Diagnostic buffer is full of errors from the module and OB82 is...
2,839
So I'm following a programmer who has done a few things that I don't completely understand. This is in a GE RX3i PLC. First of all, he used 250...
1,795
Last year at about this time I was invited to go to the National Airport Pavement Test Facility to help out with their test system. Usually our...
7,585
