Unity PLC & FS GATEWAY
Jun 2002
Lahore, Pakistan
In my project I have 11 concept and one unity PLC. Concept PLCs are communicating fine with intouch, while unity is creating problem. The analog values comming from unity are jumping continuously from minimum to maximum.
In OFS configuration I have defined unity PLC as concept. The reason for that is when I define unity as unity I get nothing in intouch and also all the tags of unity PLC in FSgateway diagonstic become red while in other case(when defined as concept) these tags are green but show jumming values. Please help.
Best Regards
Can you Please explain a bit more, like what driver/server you are using for getting data from unity PLC.(is it something like PLC-->driver--->FSG--->InTouch)
If you are getting data from the PLC to the unity- driver/server correctly and FSGateway (in its diagnostics) is showing item as red then there probably be some configuration issue.
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
GitHub Link: https://github.com/Automation-Standard/Open-Industry-Project This is a little side project I've been working on that I felt would be...
3,428
As part of a comprehensive site survey, I have to mobilise to a remote site (offshore). I have also been asked to take a backup of their PLCs, so...
2,254
I was wondering if there is a way to convert the PLC code sections .XBD into excel, edit them, and reimport them.
1,208
Hi All, Just wondering if anyone out there has a good comprehensive dual drive monitoring FB for Unity Pro, we had an issue on a site where a...
1,109
