Unity pro and M340 - data logging
pazuzu
Jul 2013
Poland
18
Hi
Is there any example or tutorial with description about data logging on PLC?
I want to save a 365 entries containing a actual date and 3-4 variables. I want to save it on the memory card and after that i want to view this file from HMISTU panel and from SCADA.
Is it possible?
Thanks.
Sorry to drag up an oldy but I had the same question.
Look up the file functionality, you can create files on the memory card and write to them, read from them, delete them etc from within the PLC program. You can also access the files via FTP if you have the correct model NOE module, I think better than NOE0100 is required.
For reading from scada though you will probably have to select the file and read it all in to memory, unless your scada will get it via FTP.
Greetings, I'm new at PLC programming, but good a logic - so I thought. I've inherited a PLC system, which is presently operating in the field...
2,490
If I am disconnected from M340, I cant see the Values. Unlike RSLogix when one gets to choose upload state values upon exit, and these state...
2,267
I am trying to make a function that count the number of True BOOL inn a specific Array and return the count to an INT AlarmArrayActiveAlarms. I...
4,444
Hello all, My company have sourced a Modicon M340 PLC with a Magelis (XPT GTO4310) HMI. The intention here is to use this setup in order to...
3,703
I am having trouble with creating a shift register in Unity Pro on my Schneider M340. I am using the FFB SHR to try and get this to work. I have...
5,093
