Unity Pro and OPC factory server problem
jscott
Feb 2017
vancouver
**Edit, ok I think that the OFS simulator is, well, a simulator so doesn't actually connect to the PLC, weird that I can get the tags from the PLC though...I don't have the license for the full OFS, is there an OPC server I can use with these 2 programs? **
Hi all I'm trying to connect Unity Pro to OFS (and Vijeo Citech)and the values showing up in the server are just random numbers it seems. Booleans toggle on and off repeatedly, with no change in the PLC program.
I've set up a device alias in OFS configuration Tool, and my tags (from Unity)show up. But when I check the values (In Vijeo and OFS Client) they are all wonky!:mad:
Any ideas on what's missing?
I am running these all on 1 PC. Using Unity Pro simulator and OPC Factory Server simulator.
I've got Unity and Vijeo working together without the server, but can't get this last piece to work. I've read and done every tutorial I can find, but there doesn't seem to be much info out there.
Thanks!!!!!!!!!!!!!!!!!
Thanks @VON_Hydro. I'm doing that and it works well for learning Citect and how they work together. But it's the server side of things that I'm fairly clueless about and trying to learn. Also, can one make trends with that setup?
I'll be doing some work in a plant with a Unity-OFS-Citect set-up, so trying to get a jump start on practising.
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
721
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,937
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
