Unity Pro Documentation
Marie1982
Feb 2007
House
121
I want to use the Documentation functionality in Unity PRO from Schneider. When I expand the folder, I only avec a Title page subject and a General subject. It says in the help that I can rightclick on a subject (example Configuration) dans do a Add header command or Edit/Include header to add a subject to the Documentation tree.
However, I don't see the Add header command or and I don't have Include header in the Edit menu.
Anyone knows how to do this?
All I'm trying to do is a configuration report to put in my printed documentation. (sooo easy to do with RSLogix or the Advantys software)
You must double click on the documentation link and not expand it. Once double clicked a window will pop up where you can select structural or functional view. In that window you can right click on something and include a header or whatever...............So you see, also sooo easy to do in unity :)
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
717
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,929
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
