Unity Pro Export Variables list (DDT)
Mar 2012
Sydney
Hi All
Great website, I have found it very useful. Thank you all for your past, present and future replies.(y)
I have completed my Unity 5.0 program and have used DDT's (Derived Data Types) which are all working well when I simulate, so happy with that.
However I want to create a check list for testing on site. When I export variables in to Excel it doesn't bring accross addresses inside a DDT.
Is there a special step to export DDT internal addresses?
Thanks in advance
MechMan(y)
Hi Mechman,
Funnily enough, I've never actually tried to do this. I've just had a poke around Unity Pro L 6.0 and can't seem to find any way to export the actual elements inside each DDT either!
Exporting to XSY format (basically an XML document) would allow you to do a bit of copy / pasting to make up a variable list but that's probably just as much work as typing it up by hand.
Maybe someone else knows a way...
Thanks for the reply Saffa
Yeah I tried the XSY, however for me that still didn't have any "internal" Addresses in the DDT.
I've attached a picture of the results
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
779
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
184
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
407
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
728
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,942
