Unity Pro Help
dave.fish
Dec 2008
Savannah
I am trying to open a *.stu file in Unity Pro XL but it keeps telling me I must use the *.xef file. I saved the file I was working on but never exported it. Any help?
What version Unity pro are u using. If u use the same version then should be able to open a stu file. But If u r trying to open an older version with new , Then u need a sta or XEF file.
If you are using the lowe version such as v3.0 or 3.1 or ... etc, you must esport your project file to .XEF with your build version.
Then you can import your .XEF file with a new version such v4.0.
After that you can save/store in .STU with your new version of Unity.
try changing the .stu file extension to .sta this used to work, apparently the sta file is stored as part of the stu file
Hi all, I have a request from client as follows, There's one PID for Control valve which would be controlling on basis of temperature. One...
1,524
Greetings, I'm hoping someone here has a trick for viewing/reporting tag values from the .DTX files saved from the PLC using Unity Pro XL? We...
3,542
Trying to figure out how to find/build a retentive timer. Any help much appreciated.
1,896
Hello all, I am developing HMI screens for a Wastewater Treatment Plant which is using Modicon M580 PLCs that are running Unity Pro XL version...
3,862
Anyone have experience using Unity Pro function block MUX command words to read serial data? We are upgrading from an Allen Bradley PLC 5/40 to a...
3,192
