Unity Pro - How to move Bool to all bits in an INT?
FNC
May 2010
NJ
84
I am using Unity Pro XL 4.1
Is there an easy way to move a Boolean value to every bit of an Integer?
There is a function for moving a boolean to an array of Booleans(MOVE_BOOL_AREBOOL)butit will not allow use of integer there.
Any help would be appreciated!
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
182
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
406
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
725
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,939
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
775
