Unity Pro.Random Number Generator
Stergios
Jan 2008
Greece
Hi,Does anybody know if there are any routines in unity pro that produce random numbers like the routine rand() in C ?
I would develop logic that generates a number as a function of time.
BTW- I remember from advanced programming courses in collge that a computer cannot generate a truely random number. It has to be based on somethig, therefore does fit fit the definition of random. 'If one of you could develop code that generated a truely random number, you will be a millonaire.' the proffesor stated.
I think I will get to work on it immediately. just kidding.
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
177
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
402
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
713
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,928
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
774
