Unity Pro S + Altivar 320 VFD
jfischerr
Jul 2013
St. Louis, MO
Good Afternoon Guys,
I am learning/using Unity Pro S. It is very new to me as most of my experience is with Automation Direct and Allen Bradley. I have a M340 processor and am attempting to control some Altivar 320 VFDs through an NOE 0100 module. I believe I have my i/o scanning set up correctly, but I am confused on how to actually control the drives. We are only looking to start/stop and set Hz. I feel like I'm reading the manual over and over with no progress. Can anyone send me to a better instruction guide or have an example of how to set this up?
I should probably mention I am programming offline because they are still building the panel out in the shop and just want to eliminate as many possibly problems as I can ;)
Thanks!
Joe
You can't just turn on the VFD by classical start/stop and by changing frequency. You need to control CMD (Control word) and ETA (Status word), and LFRD (Speed setpoint). After switching on and when an operating mode is started, Altivar goes through a number of operating states - so called State Machine. There is diagram in manuals.
Hello. I urgently need to control 10 altivar12 with m340 plc with MODBUS. Could anyone help me how we can control this drives from modbus in unity...
5,016
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
721
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,934
