Unity Pro S Freezes
Novice2015
Sep 2015
UK
Just wondering if anyone had the problem of Unity Pro S freezing when they try to delete any FB from an FBD section?
Do you see runtime error or some other fatal error for Unity
you need reinstall Unity completely. Ask from Schneider upcleaner tool for Unity (upcleaner have to be same version as your Unity installation).
It will clean all registry settings which can left after normal uninstallation then installa Unity again to PC
It resolved same problem for me
Thanks Lare,
I get a Fatal error "The thread tried to read from or write to a virtual address for which it does not have the appropriate access".
I uninstalled Unity and ran UPCleaner V8.0 and reinstalled Unity as you said and the problem is resolved.
Thanks for your help.
I had same problem last week with newest Unity pro. Error message was pretty much same and program freezed.
Welcome to the forum.
p.s There is pretty much hotfixes for 8.0
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
191
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
414
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
741
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,957
Hi, I've exported a PL7 application to the .FEF file succesfully. Imported the .FEF file in my Unity Pro project, but two of the five sections in...
782
