Unity pro status information codes
atomtm
Jun 2014
Germany
130
Hello everyone !
Is there a list for status information codes in diagnostic viewer? I am getting s908 remote I/O Failure with status information 16#32CA and would like to debug this error.
Is there a way I can have more insight on this problem ?
Thank you in advance
search from Unity pro help files: "Diagnostic IDs"
Diagnostic ID / Warning message / CPU LED display message
13002 / S908 Remote I/O inoperative / s908 fails
Thank you very much for your response.
Is there a chance you know possible reasons for this , or a way i can look at it?
Thank you Lare!
Anyone else with experience on that kind of error . What I am looking actually is a way to look into it , not a definite answer
Hello all, I am developing HMI screens for a Wastewater Treatment Plant which is using Modicon M580 PLCs that are running Unity Pro XL version...
3,853
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
717
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,929
