Unity Pro System Bit %S65
gripster
Dec 2010
Londinium
40
Where are you?
Where do you find the system bits?
In short all I want to do is set this bit to zero so I can remove the memory card! Surely I do not have to put code into the program to do this?
I am fairly used to RSLogix500 now but this Unity stuff is perplexing, I feel quite at ease with the ST and FBD having done some stuff in C at Uni but finding my way round some of this basic stuff is really time consuming. It takes as much time to find you way round the programming interface as it does writing sections of code. o_O
gripster,
In your project browser right click on animation tables and create a new Animation Table. You can call it anything you want.
In your Animation table enter: %S65 under name.
Make sure Modification is selected. While online and connected to the PLC change the value from 0 to 1.
Pe+ycppTZO4AAAAASUVORK5CYII=
Hi All, I have a job to make a diagnostic program to M340 and Momentum(two job same logic), M340 program done but momentum plc was facing program...
1,837
OK Gang, I'm setting up a M340 system using Wonderware as the HMI and I really want my DASMB server to match the addressing in the PLC and not be...
2,202
Hi everyone, im trying to read/write the system clock on a M340, by building a program in unity pro. The thing is, that the Date&Time format is...
46
50,638
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
188
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
409
