Unity Pro & Concept 2.6XL System Bits
jin1016
Nov 2016
singapore
Hi All,
I have a job to make a diagnostic program to M340 and Momentum(two job same logic), M340 program done but momentum plc was facing program problem :
Question:
I need use these similar system bits in momentum
%S11(Watchdog overflow),
%S15(Character string fault ),
%S18(Overflow or arithmetic error ) ,
%S19(Task period overrun (periodical scanning) ),
%S20(Index overflow ) in M340
But momentum don't have system bits. Using PLCSTAT this function block now.
Anyone can help me? Thanks.
Hi All, First time poster and PLC novice so please bare with me. I currently have a M340 which will be going into a cabinet, this M340 will be...
1,491
I converted a Concept program to Unity Pro XL and all went well except when I build the project in Unity Pro I get these errors: 1. The...
5,362
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
188
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
409
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
732
