Modicon Unity Pro XL-Concept "config binary generation error"
sfestiva
Jan 2007
tampa
I converted a Concept program to Unity Pro XL and all went well except when I build the project in Unity Pro I get these errors:
1. The allocated memory size of %MW must be a multiple of 8 words
2. {Configuration}: Configuration Binary Generation Error
Any ideas?
Thanks in advance
Set the allocated memory size of the %MW table to a multiple of 8 words
You will find this setting by clicking on the cpu and going to the config tab
Thank you Geo!
But I am still confused on where to set the MW allocation to 8
This is the config screen and the error I am seeing:
Thank you in advance!!
I changed the allocated MW memory from 2123 to 2120 ( I am assuming to be divisable by 8 as mentioned in the help?)
After I did that, the build is successful
Thanks Geo!
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hello all, My company have sourced a Modicon M340 PLC with a Magelis (XPT GTO4310) HMI. The intention here is to use this setup in order to...
3,697
Greetings, I'm using Unity Pro v8 (131118) with Modicon M340. I cut my teeth on PLCs with Modicon back in the early 90s but this is my first...
2,652
I was wondering if anyone knows if I can use the Unity Pro software to download an backup the logic from an older Modicon Micro CPU612?
1,633
Hi I have a modicon 984 and HAD a pc issue with the dev PC that had the Proworx 32 software and programming on it. The hard drive took a dive and...
5,718
