Unity Pro XL 4.1 Fatal Error
Darkshrimp
Mar 2011
WA
20
Recently reinstalled Unity Pro XL 4.1 on the system and now I can't save files without getting a fatal error.
Anyone seen this before?
is it 6-7 years allredy when 4.1 was published. Try to get newer CPU models and cards to use and updating is must after that :D
(or even after if someone makes changes to program with newer version...)
Just did that, still doesn't work :(
is it giving same error also for saving original project or modified only. Can you try installing to different PC and look if it works there.
Did you do installation with antivirus program disabled?
Just tried using the same installation file on another computer that's running 64bit Windows 7 Professional SP1 and it has worked... :(
version 5 was win7 32bit compliant and later camed 64bit support (maybe with version6 or 7)
It can work, but there is no 100% guarantee for that
http://www.east-med.schneider-elect...en&locale=en_US&id=FA86466&prd=&redirect=true
If unistalling and cleaning with upcleaner software don't work,
easiest way would maybe be to update newer version or use another laptop
I just tried upcleaner again, the trick this time was running it twice.
It has now worked. Thanks Lare!
Hello everyone, I am having a problem with my Unity Pro v.11. When I try to open the software I get this fatal error: Unity Pro XL Fatal error...
10,482
Hello, I am using Unity pro V15. I have Quantum CPU 671 and Ethernet NOE 77101 configured. I have configured IO scanning on NOE. I have attached...
179
HELLO MY FRİENDS ı have problem. ı tought you can solved thıs problem for me. First of all When I checked all the cable connections of the...
404
Hi All, I haven't installed Unity Pro in years and needed to install it recently. I initially tried installing Version 11.1 and the whole...
721
Hello i want to implement a Read_var / Write_var functions to communicate with a modbus tcp device at the moment i use the unity simulator at the...
1,933
