Unity Pro XL and M340 example project.
vanko11595
Dec 2014
Sofia
Hi, I am newbie at programming PLC's so I need M340 Unity Pro example project.
Simple draining pump station with three pumps.
First pump starts at level one. If it fails to start the second pump starts at level two and if both first and second pumps fail to start third pump starts at level three.
There must be rotation of the sequence of the pumps when the tank is empty, namely at level zero. So, at first cycle - level one must starts pump one, at second cycle - level one must starts pump two, third cycle - pump three starts at level one, fourth cycle - again pump one starts at level one etc.
Any help will be appreciated :)
I need this too!
You might notice the fact this question was asked nearly 4 years ago and didn't receive an answer, that's because nobody has ready made PLC programs for this sort of request.
What have you got programmed so far that you are struggling with ?
Greetings, I'm new at PLC programming, but good a logic - so I thought. I've inherited a PLC system, which is presently operating in the field...
2,490
If I am disconnected from M340, I cant see the Values. Unlike RSLogix when one gets to choose upload state values upon exit, and these state...
2,267
I am trying to make a function that count the number of True BOOL inn a specific Array and return the count to an INT AlarmArrayActiveAlarms. I...
4,444
Hello all, My company have sourced a Modicon M340 PLC with a Magelis (XPT GTO4310) HMI. The intention here is to use this setup in order to...
3,702
I am having trouble with creating a shift register in Unity Pro on my Schneider M340. I am using the FFB SHR to try and get this to work. I have...
5,083
